Cross-fade clips
geosv
Cross-fade clips
Post by geosv » Fri Sep 11, 2015 5:14 am
Just got the latest version with this feature. The cross-fade fails to cross-fade. It only fades out the first half and fades in the second. Wrong terminology isn't it.
Re: Cross-fade clips
Post by Gale Andrews » Fri Sep 11, 2015 2:52 pm
geosv wrote:Just got the latest version with this feature.
Try reading the pink panel at the top of the page and giving us that information. Latest version could mean 2.1.1 or 2.1.2-alpha and that could make a difference.
geosv wrote:The cross-fade fails to cross-fade. It only fades out the first half and fades in the second. Wrong terminology isn't it.
Try reading this Crossfade Clips - Audacity Manual. Did you notice that the track length is reduced after the crossfade?
geosv
Post by geosv » Fri Sep 11, 2015 8:17 pm
For the moment I'll just reply 2.1.1. Are you saying 2.1.2 changed it? I saw no offer of a 2.1.2.
I'm describing my result.
Post by Gale Andrews » Fri Sep 11, 2015 8:24 pm
geosv wrote:For the moment I'll just reply 2.1.1. Are you saying 2.1.2 changed it?
In this case, no. But I'm saying to save ambiguity, please always give all three version numbers (plus for alpha builds, the date that is part of the version string).
geosv wrote:I saw no offer of a 2.1.2.
2.1.2 is not released yet, hence the -alpha designation. The -alpha builds are development builds between releases. Please see Nightly Builds - Audacity Wiki.
