Recording Streaming music [SOLVED]
csatennis
Re: Recording Streaming music [SOLVED]
Post by csatennis » Thu Sep 10, 2015 5:21 pm
OK, found it. Apparently during a microcrap upgrade, they changed my settings so that I had a different recording option. I changed it back and it is fine now. Thanks for the suggestion to look at my microphone settings.
rob
