Export button is grayed out?
I was putting some audio through audacity for a tutorial on how to use HLDJ (Unrelated), anyways I did the same things that the guy in the video did but when I had to export the file the export buttons (and a lot of the other ones) were grayed out... I did everything that the guy in the tutorial did but they were grayed out, any help appreciated!
Re: Export button is grayed out?
Most functions require playback and recording to be "stopped" (not just "paused"). Try clicking to Stop button.
