Contracting the entire cell after accidental expansion
Richard Blum
Post by Richard Blum » Fri Sep 04, 2015 8:49 pm
Windows 7. Audacity 2.1.1 When I am editing, sometimes I move the cursor to far to the left and the cell window grows unevenly. I notice the little + icon in a microscope over the left side of the cell. How do I undo this little horror. How do I shrink it back to original size? :o
Re: Contracting the entire cell after accidental expansion
Post by kozikowski » Fri Sep 04, 2015 10:00 pm
While your cursor is in that band on the left, press one of the modification keys until it changes to [-]. On my machine, that's SHIFT.
Richard Blum
Post by Richard Blum » Sat Sep 05, 2015 4:16 pm
Thanks Koz. If it was a snake it would have bit me. Rick :D
