Apply Chain on Stop
garion1
Apply Chain on Stop
Post by garion1 » Thu Sep 03, 2015 10:02 am
Audacity 2.1.1 on Windows 8.1
Problem: When a recording is complete, I do not want to allow editing of the recorded file. I want it to apply a chain and close, preferably when stop is pressed. For example:
Option 1 (Preferable - Automated)
(Manual) Start -> (Manual) Stop -> (Automatic) Apply Chain -> (Automatic) Apply to Current Project -> (Automatic OK) Export recording window -> (Automatic) close open project
Option 2 (Simpler method - Lock track from editing)
(Manual) Start -> (Manual) Stop -> (Automatic) Lock track from editing -> (Manual) Apply Chain -> (Manual) Apply to Current Project -> (Manual) Export recording window -> (Manual) close open project
Any help will be appreciated.
Re: Apply Chain on Stop
Post by steve » Thu Sep 03, 2015 10:06 am
garion1 wrote:Option 1 (Preferable - Automated)
It may be possible tog that with an AutohotKey script. http://www.autohotkey.com/
garion1
Post by garion1 » Thu Sep 03, 2015 10:55 am
Thanks. I'll give it a try.
