Noise Gate refuses to show up After update [SOLVED]
SgtKeeneye
Post by SgtKeeneye » Wed Sep 02, 2015 10:10 pm
So I updated my Audacity to be able to use FFmpeg libraries. After doing so my Noise Gate Plugin no longer shows up. After uninstalling multiple times and then dropping the noise gate plugin in it will not show up. I have restarted it and dropped it in when closed and it still doesn't. I have been able to use it using a Nyquist Prompt as a work around but its rather annoying to have to adjust it every time. I have noticed even after uninstalling that my Chains still exist so it seems its not doing a full uninstall since those settings exist still.
What can i do to make the Noise Gate show up so I can have it has a Chain Again?
Re: Noise Gate refuses to show up After update
Post by steve » Wed Sep 02, 2015 11:56 pm
SgtKeeneye wrote:What can i do to make the Noise Gate show up so I can have it has a Chain Again?
Assuming that you are using Audacity 2.1.1, you need to enable the plug-in.
See: http://manual.audacityteam.org/o/man/ma ... yzers.html
SgtKeeneye
Re: Noise Gate refuses to show up After update [SOLVED]
Post by SgtKeeneye » Thu Sep 03, 2015 12:41 am
Thank you
