Creating a Chain with Regular Interval Labels & 2x Volume
ribblle
Post by ribblle » Fri Aug 28, 2015 1:59 pm
I know amplify adjusts the volume, but it has a slider, not a volume multiplier. I can't find regular interval labels under edit chain either.
Re: Creating a Chain with Regular Interval Labels & 2x Volum
Post by steve » Fri Aug 28, 2015 2:43 pm
By "2 x volume" I presume that you mean "double the amplitude".
To double the amplitude, amplify by +6 dB.
Chains do not currently support "Analyze" type plug-ins, only "Effect" plug-ins. Regular Interval Labels is an Analyze type plug-in.
It may be possible to work around this limitation if necessary. Why do you need Regular Interval Labels in a Chain?
Post by Gale Andrews » Fri Aug 28, 2015 3:21 pm
steve wrote:Chains do not currently support "Analyze" type plug-ins, only "Effect" plug-ins.
Analzye effects are supported in Chains as per the top of http://manual.audacityteam.org/o/man/ch ... ation.html assuming ribblle has at least Audacity 2.1.0.
Please see the pink panel at the top of the page for how to find your Audacity version number.
The current Audacity version is 2.1.1 ( http://audacityteam.org/download/windows ).
Post by steve » Fri Aug 28, 2015 3:35 pm
Gale Andrews wrote:Analzye effects are supported in Chains... assuming ribblle has at least Audacity 2.1.0.
Oops, yes. I'd forgotten that had already been added :oops:
ribblle
Post by ribblle » Fri Aug 28, 2015 8:21 pm
Thanks. How do i add export multiple to the chain?
Post by steve » Fri Aug 28, 2015 9:13 pm
ribblle wrote:Thanks. How do i add export multiple to the chain?
That one I'm sure is not yet supported.
ribblle
Post by ribblle » Sat Aug 29, 2015 9:53 am
Thanks. I heard there's more advanced scripting support, so how can i use that to script this? Or can you recommend a easier program to make this chain in?
Post by Gale Andrews » Sat Aug 29, 2015 11:24 am
You would have to compile Audacity for scripting support and then be able to program.
I gather you want to split large files into smaller equally sized files having applied +6 dB amplitude. Correct?
Are there other effects you want to apply?
What format are the original files in?
ribblle
Post by ribblle » Sat Aug 29, 2015 12:48 pm
The original files are MP3's. That's all i want to do.
Post by Gale Andrews » Sat Aug 29, 2015 1:12 pm
ribblle wrote:The original files are MP3's. That's all i want to do.
Try MP3DirectCut or similar direct MP3 editor. That way you won't lose quality re-encoding the MP3's as you would with Audacity. http://wiki.audacityteam.org/wiki/MP3#re-encode.
