regression 2.1.1: cannot play 1-sec
axd
Post by axd » Sun Aug 16, 2015 9:27 pm
in 2.1.0, '1' key allowed to play 1 second around cursor.
in 2.1.1, although key 1 is defined in the Key Bindings, pressing '1' does nothing.
(Windows 7 SP1)
axd
Re: regression 2.1.1: cannot play 1-sec
Post by axd » Sun Aug 16, 2015 9:52 pm
Update: the bug appeared in the very first start of 2.1.1. After restarting, it seems to have gone.
Robert J. H.
Post by Robert J. H. » Mon Aug 17, 2015 6:11 am
axd wrote:Update: the bug appeared in the very first start of 2.1.1. After restarting, it seems to have gone.
Probably not.
It will reappear if you start a new session.
If the short cuts "1", "c" and so on do not work:
- Hit record
- stop after a short time
- hit Undo
This sets a flag that enables those special play commands.
Robert
axd
Post by axd » Mon Aug 17, 2015 6:30 pm
