Increasing Bass - Audacity 2.0.2 Windows XP Pro
eager to learn
Post by eager to learn » Sat Aug 15, 2015 1:35 am
Hi,
Is there any easy way to increase the base of a .mp3 song?
I tired watching a youtube video and had the volume up as high as possible but could hardly hear hear it and their screen was so tiny I couldn't really see what they were doing.
Can I just slide a "bass bar"?
Thanks so much.
Last edited by eager to learn on Sun Aug 16, 2015 7:29 pm, edited 1 time in total.
Re: Increasing Bass - Audacity 2.0.2 Windows XP Pro
Post by steve » Sat Aug 15, 2015 2:15 am
See: http://manual.audacityteam.org/o/man/ba ... reble.html
Note that if you are listening on little computer speakers, you won't hear any increase in bass because little computer speakers don't produce bass frequencies.
eager to learn
Post by eager to learn » Sun Aug 16, 2015 7:43 pm
Steve,
In my version under Effect I just have Bass Boost - nothing for Treble.
When I move the slider to the right increasing the bass it sounds garbled.
Maybe I just can't augment the bass in this song?
Even it sits possible, it's probably trial and error on each audio recording.
Thanks.
Post by steve » Sun Aug 16, 2015 8:37 pm
eager to learn wrote:In my version under Effect I just have Bass Boost - nothing for Treble.
You are using an obsolete version of Audacity.
The current version is Audacity 2.1.1 and is available here: http://web.audacityteam.org/download/windows
See here for system requirements: http://web.audacityteam.org/download/windows#sysreq
See also: http://forum.audacityteam.org/viewtopic ... 46&t=84123
eager to learn
Post by eager to learn » Mon Aug 17, 2015 3:49 pm
Steve,
What are the advantages I'll gain by upgrading my version to 2.1.1?
Will I sacrifice any feature, function or ease of use by upgrading from *my* current version?
Will I notice how I must perform tasks differently (more complicated?) with version 2.1.1?
Thanks so much.
Post by steve » Mon Aug 17, 2015 4:02 pm
Basic operation of Audacity is much the same.
Benefits are: There are many enhancements, quite a lot of new features, and loads of bug fixes, plus you can get technical support for the current version here on the forum.
The possible downside is that if your computer does not meet the System Requirements, the new version will not run, in which case I would recommend using Audacity 2.0.6.
It is generally best to have only one version of Audacity installed at a time, but all old versions are still available.
eager to learn
Post by eager to learn » Mon Aug 17, 2015 4:23 pm
I searched for system requirements under the FAQ but I didn't see what they are for either version 2.1.1 or 2.0.6.
What are the system requirements for version 2.1.1?
Could you please share the link to that version?
What are the system requirements for version 2.0.6?
Thank you.
Post by steve » Mon Aug 17, 2015 4:30 pm
See here for system requirements for the current (2.1.1) version of Audacity: http://web.audacityteam.org/download/windows#sysreq
Audacity 2.0.6 does not require SSE2.
eager to learn
Post by eager to learn » Tue Sep 08, 2015 10:12 pm
Steve,
Thank you!
Version 2.1.1 looks identical to my older version but has those very helpful bass and treble controls.
Fun to use!
Thank you again.
mickthefish
Operating System: Windows XP
Re: Increasing Bass - Audacity 2.1.0 Windows XP Pro
Post by mickthefish » Wed Sep 09, 2015 8:55 am
i find the only way to get good bass recordings is to use a more powerful type of cassette deck to import your music ,rather than the hand held tape decks, which to my mind always seem a bit tinny. then again you can always alter the bass on your hi-fi player i suppose.i cant see any other way of altering bass in audacity though.mickthefish.
