Effects settings won't save
themickster
Effects settings won't save. The dialogue box opens; I click to save, but the folder shows empty afterwards, other than the subfolders that are already there.
- Quality Assurance
Re: Effects settings won't save
Please read the pink panel at the top of the page and give us the required information.themickster wrote:Effects settings won't save. The dialogue box opens; I click to save, but the folder shows empty afterwards, other than the subfolders that are already there.
Which effect(s) exactly are you talking about? Are you talking about the Manage button in an effect, then exporting a preset?
As a wild guess, try adding the extension that is required to the name. So if you are saving an XML file, add
Code: Select all
.xmlto the end of the file name.
themickster
Thank you Gale. I needed to add the .fxp.
