edwinn wrote:Labeling on the fly while recording is working VERY WELL after (temporarily) disabling the Start/Stop Spacebar shortcut.
Sorry, but there is simply no need to disable SPACE when typing labels during recording. The only way that SPACE would stop the recording is if you pressed ENTER after typing the label then pressed SPACE, or if you pressed UP arrow while typing in a label then pressed SPACE. In both those cases I think it is legitimate for Audacity to stop the recording.
If you think this is a problem, please give exact step by step instructions as to how to use SPACE to stop recording while typing a label.
edwinn wrote:While recording, the waveform progresses to ~80% across the view window, and before it runs off the right window edge or wraps, I usually DRAG the horizontal scroll bar to pull the focus, [recording] point, or cursor back toward the center. However it only goes back to 75-80% the way across. It would be best to [be able to] drag the cursor back to ~20% the way across window. This is to aid in LABELING. Some labels are l-o-o-o-n-g.
The workaround
If you know you're going to record a 1-hour or 2-hour show, then once underway [recording], ZOOM out till 1-Hr or 2-Hrs is in view in Audacity. Then click at 2-hrs [end of the show] and add a label `End´ using Ctrl+B.
Now the recording waveform can be zoomed and scrolled nearly ANYWHERE in the 2-Hr space, and on the fly.
Sorry but I cannot follow what you are describing or see the difference that the end label makes.
If you want the screen to scroll while recording I would simply zoom out far enough so that the screen won't scroll by the time you have finished the longest label you want to type. The horizontal scrollbar is not really useful if you allow scroll while recording.
If you don't want the screen to scroll while recording, I can see that does not work as well as it should. CTRL + M when you want to start a new label at the recording position does not move the screen to the position of the new label. A second CTRL + M does so, and this shows you an empty label created by the first CTRL + M.
