Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Quality Assurance
Post
by Gale Andrews » Wed Aug 05, 2015 7:47 pm
waxcylinder wrote:perissos wrote:The problem with recording larger projects [60-minutes long] is that you cannot save on the fly, like when you are editing a project.
Yes I know what you mean - I've often thought the same myself as I've been making longer un-repeatable recordings.
Either of you could "vote" for that if you wanted to. But writing while recording could potentially endanger the recording.
- Quality Assurance
Post
by Gale Andrews » Wed Aug 05, 2015 7:50 pm
cyrano wrote:perissos wrote:I will still have to cut and paste 632 sectors together, but it is better than what I had before.
Have you considered using some macro tool to do that job?
No need - perissos didn't understand when he wrote that the 1.2 Recovery Utility pieces the AU files together into a WAV.
waxcylinder
Post
by waxcylinder » Wed Aug 05, 2015 10:09 pm
Gale Andrews wrote:waxcylinder wrote:perissos wrote:The problem with recording larger projects [60-minutes long] is that you cannot save on the fly, like when you are editing a project.
Yes, and that's why I dream rather than vote ...
and rely on automatic recovery
perissos
Post
by perissos » Thu Aug 06, 2015 3:00 pm
Thanks for all of your replies. Gale suggested using the file manager utility above for managing the data files, which allowed me to sort by 'date_hr:min:sec'. It was the 'seconds' sorting that I needed, so that all the files were arranged chronologically.
The file is now reassembled, fixed and ready to roll.
Hopefully, as pointed out above, this version of Audacity will be more stable than the past ones.
Thanks 'waxcylinder' for your tips...brilliant.
all the best, Jerry
