h-h wrote:I think three dots are just a "less professional" way for the ellipsis that also has its own Unicode character. A really great user interface would also take no-break spaces into consideration, the correct dash lengths and would use a number of other Unicode symbols, e.g.
minus.
In computer science, first comes the usage and the rules afterwards and they are naturally dictated by the majority which in this case consists of major companies and an English based GUI.
In my opinion, the three dots after a menu entry are a random choice by any obscure GUI developer and afterwards artificially connected to the ellipsis symbol.
One can as well compare them to a table of contents, where the lines are just filled up with dots.
It is just an indication that there is more to follow - a dialogue in the GUI case and a page number in the TOC case.
In a lot of places, Utf-8 is not available but only e.g. Latin-1 or another code page.
Try e.g. "Sample Data Export" (Analyze menu) to a file like "Hörbaispiel", it won't be saved correctly.
What's more, assistance technology (screen reader) has a lot of Unicode Characters not defined per se. Especially the minus sign comes in a lot of versions and is not always correctly assigned.
h-h wrote:But that's something not taken serious or its considered a minor minor minor issue. If a user interface would even use the correct system font size, much would be won.
Do you mean the correct Dpi scaling here?
Robert
Robert
