Windows 10 Problems
thomasbutler
Windows 10 Problems
Post by thomasbutler » Sun Aug 02, 2015 5:24 pm
Hey. I recently upgraded to Windows 10 and was going to edit a file on Audacity, but every time is says there is an internal audio port error when I have a working audio port for iTunes. Please someone help. I've already tried reinstalling ASIO4ALL
Re: Windows 10 Problems
Post by kozikowski » Sun Aug 02, 2015 6:16 pm
Audacity doesn't support ASIO, so it doesn't matter which drivers you install. You're pretty much limited to the normal Windows drivers and services. I don't know what those are because I'm a Mac elf. Other elves will be along.
Post by Gale Andrews » Sun Aug 02, 2015 6:18 pm
kozikowski wrote:Audacity doesn't support ASIO
Audacity as shipped does not support ASIO.
If you compile Audacity from source code, you can add ASIO support to it.
Post by Gale Andrews » Sun Aug 02, 2015 6:21 pm
thomasbutler wrote:Hey. I recently upgraded to Windows 10 and was going to edit a file on Audacity, but every time is says there is an internal audio port error when I have a working audio port for iTunes.
Audacity does not officially support Windows 10 yet.
The first step is to go to the web site of the computer manufacturer or motherboard manufacturer and see if you can find audio drivers for Windows 10 meant for your specific computer.
If that does not help, see this topic
http://forum.audacityteam.org/viewtopic ... 46&t=86720
and similar ones on http://forum.audacityteam.org/viewforum.php?f=46.
Robert2
Post by Robert2 » Sun Aug 02, 2015 6:50 pm
Here is from http://pureinfotech.com/2015/07/31/wind ... -features/:
“According to The Verge, Windows 10 Service Release 1 could arrive as early as next week. However, the servicing update won’t include any new features, it will only fix some of the problems users have been reporting with Windows 10.”
