Audacity 2.1.0
How to export Chain settings in case I reinstalled windows?
- Quality Assurance
Re: How to export Chain settings in case I reinstalled windo
There is nothing to export. Assuming you are on Windows Vista or later, the text files for each Chain are already saved at
If you are on the insecure Windows XP:
It is perfectly possible to reinstall Windows and retain the settings in your Users folder, though backing up data first is always a recommended precaution.
Code: Select all
Users\<your user name>\AppData\Roaming\Audacity\Chains\If you are on the insecure Windows XP:
Code: Select all
Documents and Settings\<your user name>\Application Data\Audacity\Chains\Gale
Exactly.
Thanks
Thanks
