Serious problem with the effect peak-limiter.
юра00
Post by юра00 » Fri Jul 31, 2015 2:51 pm
It doesn't work or works very slowly, 2 minutes or more, when defaults. Please, help, explain and correct. Also for Limiter, Brick-wall limiter.
Re: Serious problem with the effect peak-limiter.
Post by steve » Fri Jul 31, 2015 2:56 pm
Please state which version of Windows you are using, the exact three-section version of Audacity (see: "Help > About Audacity")
Which "peak limiter" effect are you using? (please post the address of where you obtained it).
юра00 wrote:It doesn't work or works very slowly
What exactly does that mean? We can't see over your shoulder, so you need to describe exactly what you are doing and exactly what is happening.
юра00
Post by юра00 » Fri Jul 31, 2015 3:15 pm
2.1.2 alpha 31.07.
юра00
Post by юра00 » Fri Jul 31, 2015 3:16 pm
Download Peak-limiter.ny and Brick... from the page:
http://forum.audacityteam.org/viewtopic ... 42&t=59143
I don't change default parametres, appling and unknown, where finish!
Post by steve » Fri Jul 31, 2015 4:05 pm
Those screenshots appear to show it working correctly :?
юра00
Post by юра00 » Fri Jul 31, 2015 5:41 pm
Not correcly, it can't finish, 'remaining time' is increasing, not reducing, endless processing.
юра00
Post by юра00 » Fri Jul 31, 2015 5:43 pm
10 minutes remaining - it is wrong!
юра00
Post by юра00 » Fri Jul 31, 2015 6:03 pm
To my mind, the problem has appeared for 31.07 version only. Yes, for version alpha 27.07. all is working. Please, correct the last version.
DVDdoug
Forum Crew
Post by DVDdoug » Fri Jul 31, 2015 6:26 pm
viewtopic.php?f=42&t=59143
I've never tried that plug-in...
Try the new Limiter effect that comes with the current version of Audacity (2.1.1). It's got quite a few options & settings so there's a good chance you can accomplish whatever you're trying to do.
On my computer with the default settings, it took 4 seconds to process a 3.5 minute song.
юра00
Post by юра00 » Fri Jul 31, 2015 6:52 pm
I say about alpha 2.1.2 31.07.15. Thank you, new "Limiter" is interesting, not comlicated, when 5-6 undefined parametres, and useful effect!
