Sound like a "click" in my voice recordings [SOLVED]
przemekm
Post by przemekm » Tue Jul 28, 2015 12:20 pm
Hi everyone,
I have strange issue with my records. When I record, there in waveform some strange sounds, like a "click" ,recording too. I add a sceen, so if you can help me with this, I will be glad for you help. And apears too, when I record, but not talk. I am using microphone Plantronics with external sound cart for USB.
Best,
Przemek
sound of audacity.jpg (146.21 KiB) Viewed 538 times
Trebor
Re: Sound like a "click" in my records
Post by Trebor » Tue Jul 28, 2015 3:50 pm
przemekm wrote:... apears too, when I record, but not talk. I am using microphone Plantronics with external sound cart for USB.
Possibly a driver-conflict : one driver can interrupt another , causing the click .
You could test if the problem is specific to Audacity by using windows built-in sound recording device.
If the click problem persists when using Windows sound recorder, then Audacity can be ruled out as a cause of the click.
DVDdoug
Forum Crew
Post by DVDdoug » Tue Jul 28, 2015 5:06 pm
If that doesn't help, it might be the same problem/solution as this.
przemekm
Post by przemekm » Sat Aug 29, 2015 3:10 pm
Hi there,
Thank you for all suggestions but I still can not resolve this "click" sounds. I have old headsets with microphone (mini jack) and it is everything ok. But when I connect Plantronics for USB, I have this strange sounds. I am tried disable basic device sound card, antivirus, wi-fi , restart computer, change some settings in preference, but this sounds not disapears.
Any suggestions before I go to the service guarantee?
Best regards,
Przemek
Trebor
Post by Trebor » Sat Aug 29, 2015 8:40 pm
przemekm wrote:... this sounds not disapears.
Increasing the priority of Audacity to "Above normal" is worth a try : if you do that Audacity is less likely to be interrupted by other processes running on the computer. [ it's a long-shot ].
https://www.google.com/search?q=set processor priority "above normal"
If you let us have a clip of the audio which includes the click(s), that may help diagnosis :
You can attach a 5 second WAV-format file to posts in this forum.
przemekm
Post by przemekm » Sun Aug 30, 2015 7:01 am
Hello,
Thank you for reply.
I just add 5-second WAV-forma file and also waveform. There are strange sound "click" beetween 1,5-2 sec (red color) exactly like I say.
Please foregive me my English accent. It is very funny.
best
Przemek
strange sounds.wav
strange sounds like "click"
(706.04 KiB) Downloaded 19 times
waveform
strange sounds.jpg (104.04 KiB) Viewed 491 times
Trebor
Post by Trebor » Sun Aug 30, 2015 12:55 pm
przemekm wrote:I just add 5-second WAV-forma file and also waveform. There are strange sound "click" beetween 1,5-2 sec (red color) exactly like I say. Attachments strange sounds.wav
I'm confident those clicks are produced by your mouth, saying the plosives "g" "t" & "d" , rather than artefacts created by electronics or software.
The clicks can be removed in Audacity using a De-Clicker plugin made by Paul-L ...
Paul-L's DeClick plugin on default settings.gif (99.95 KiB) Viewed 487 times
''strange sounds'' before-after Paul-L's DeClick.wav
(709.63 KiB) Downloaded 23 times
However you may be able to prevent the plosive clicks happening in the first place using a pop-shield , ( an improvised one can be as good as a store-bought one).
BTW you posted a WAV-format audio file , but it sounds like it has lossy compression artefacts , as if you'd (repeatedly?) saved your recording in the MP3-format. If you want the highest sound quality you should not use MP3-format when you make your project. Only use MP3-format in the final step when making a copy to send to your customers.
[ NB: there is a quality "bit-rate" setting for MP3's: the higher the quality the bigger the file ]
Reason: Point link to released Manual
przemekm
Post by przemekm » Tue Sep 01, 2015 7:55 am
Hi,
I am suprised that saying "g" "t" "p" is cause this strange sounds. You can be right. But is strange, that my "no name" old microphone (on headset) is better than Headset Plantronics C320 USB. I think, that USB can be cause, too.
With pop-shield can be problem, because I have headset with microphone, so I can add there any pop-shield.
Anyway, plugin De-Clicker deleted 80% strange sounds and for now records is much cleaner. Big than you for this. Maybe You have another plugins, that help with cleaning records from unexpected sounds?
And than you for advice with mp3-format and wave-format.
Trebor
Post by Trebor » Tue Sep 01, 2015 5:28 pm
przemekm wrote:With pop-shield can be problem, because I have headset with microphone
You could try positioning the headset-mic further away from your mouth , and/or wrap some foam around it.
cyrano
Post by cyrano » Tue Sep 01, 2015 9:10 pm
Could the fact that this is noise-cancelling mic with dynamic eq have to do with the problem?
Plantronics used to have details for their tech on the site but that seems to be gone...
