Update from 2.1.0 to 2.1.1: Some keyboard shortcuts lost
Chardonnay
Post by Chardonnay » Wed Jul 22, 2015 10:06 am
The update from 2.1.0 to 2.1.1 led to the loss of some keyboard shortcuts. In my case of: 'Normalize' and 'Add silence'. No big deal as I re-added them manually.
OS: Windows 7 SP1
(Exactly the same problem occurred on my second machine with OS X 10.10.4; I didn't cross-post it in the Mac OS X forum.)
Re: Update from 2.1.0 to 2.1.1: Some keyboard shortcuts lost
Post by Gale Andrews » Wed Jul 22, 2015 12:07 pm
Starting from a clean audacity.cfg in 2.1.0 on Windows 7 x64, I cannot reproduce that. I assume you mean Generate > Silence.
Does your audacity.cfg still show
Code: Select all
[NewKeys]
Silence...=F8
Normalize...=F9
