Window's 10 Compatibility
PreacherAl
Post by PreacherAl » Tue Jul 21, 2015 7:42 pm
Have you received an advanced copy of Window's 10 and will Audacity be compatible with it when it comes on on July 29th?
Re: Window's 10 Compatibility
Post by kozikowski » Tue Jul 21, 2015 8:18 pm
Since everybody is struggling with current OS compatibility problems, I'd guess no.
Are you volunteering?
PreacherAl
Post by PreacherAl » Wed Jul 22, 2015 3:46 am
Once I get Windows 10, what would you be looking for? Just to try it out and let you know what works and doesn't work?
Alan
Post by kozikowski » Wed Jul 22, 2015 3:52 am
Anything, really. I posted the idea to the other elves. It's too late to back out.
Post by Gale Andrews » Wed Jul 22, 2015 12:32 pm
PreacherAl wrote:Have you received an advanced copy of Window's 10 and will Audacity be compatible with it when it comes on on July 29th?
As it says on http://audacityteam.org/download/windows#sysreq Audacity 2.1.1 will not "officially" support Windows 10.
We don't receive anything from Microsoft. A developer tried some of the preview builds and I will be trying to find the final RTM version 10240 in the next few days. However some users who had tried earlier preview versions of Windows 10 said that Audacity seemed to work OK.
PreacherAl wrote:Once I get Windows 10, what would you be looking for? Just to try it out and let you know what works and doesn't work?
Yes please, especially anything that used to work in Audacity in your previous Windows version and now doesn't.
q jordon
Post by q jordon » Fri Jul 31, 2015 6:22 am
Just downloaded Win 10 ...
Below is the Initializing Audio Error I received while opening Audacity....
Could not find audio devices.
You will not be able to play or record audio
Error: Internal PortAudio error
Post by steve » Fri Jul 31, 2015 10:08 am
q jordon wrote:Just downloaded Win 10 ...
See this topic: http://forum.audacityteam.org/viewtopic ... 10#p231615
