What does "Stopped" mean in the left lower corner?
Only for version 2.1.1.
- Attachments
- пост2.png (76.91 KiB) Viewed 321 times
Re: What does "Stopped" mean in the left lower corner?
It simply means Audacity is not recording, or playing. In other words, the playhead is not moving through the audio file...
Thank you, really. simply, "Stopped - Plaing". And another, please, "Snap to" - how to choose 1. Off 2. Nearest 3. Prior?
Thank you (I don't guess to look in manual)!
