Paranormal EVPS, SCD-1 Sessions
caseyparnell
Post by caseyparnell » Sat Jul 11, 2015 11:14 pm
If anyone is familiar with Paranormal EVPS, SCD-1 (Spirit Communications Device) I'm trying to figure out how to use Audacity for those recordings. I have Windows 8. Any help would be appreciated. Thanks!
Trebor
Re: Paranormal EVPS, SCD-1 Sessions
Post by Trebor » Sun Jul 12, 2015 6:16 am
Looks like it just randomly plays radio channels, each for a short interval of time ... https://youtu.be/unVtOB_zmR8?t=3m10s
"Robert J. H." wrote code for Audacity which will alternate [chop] between two tracks, see ...
http://forum.audacityteam.org/viewtopic ... 19#p233319
which produces a similar effect ...
Alternating between 2 speeches by Dubya.wav
chopped-up using Robert's code
(687.88 KiB) Downloaded 23 times
[ NB: No ghosties : it's audio-pareidolia ]
