Samson G-Track Headphone output right ear quiet
Npstyle
Re: Samson G-Track Headphone output right ear quiet
Post by Npstyle » Sat Jul 11, 2015 7:04 am
Hey!
Okay i'm just so confused about how it's malfunctionating after a few weeks of no usage. I'll try the alcohol cleaning method you mentioned! I'll be reporting the results after it, but thanks for the quick help, i really appreciate it! :)
Sincerely
Npstyle
Post by kozikowski » Sat Jul 11, 2015 8:10 pm
While equipment failure generally follows some activity like "I used it last week and it stopped working," it doesn't have to be. Failures are not scheduled events.
According to the Venn diagram, the microphone is working as a microphone (it is, right?) the headphones are working as headphones connected to different things and the computer is working. That leaves the headphone connection inside the microphone.
Is the headphone sound in real time? Is there a delay between the time you sing and the time it comes to your headphones unbalanced?
Npstyle
Post by Npstyle » Sun Jul 19, 2015 8:30 pm
I'm sorry I answered so late, i was on a business trip :(! I tried the method with alcohol, didn't worked.
The microphone is working fine as mic. There is no delay between speaking and hearing!
Npstyle
Post by kozikowski » Sun Jul 19, 2015 9:06 pm
Did you keep the microphone receipts?
Npstyle
Post by Npstyle » Tue Jul 21, 2015 2:45 pm
Hello!
I bought it from Thomann ~3-6 Months ago, i guess i'll use the 3 years warranty they provide!
I'm sorry that i bothered you with my problems, i really appreciate it that you helped me out :D!
Thanks!
Npstyle
Post by kozikowski » Wed Jul 22, 2015 2:45 am
It's not a problem. It can be difficult to troubleshoot complicated computer systems.
