file was mixed into 2 stereo channels on saving - undoable?
Re: file was mixed into 2 stereo channels on saving - undoab
Post by steve » Tue Jun 23, 2015 11:04 am
If you "saved" the Audacity project (File menu > Save), then the project will still have the original track layout.
That is probably your only chance of recovering the separate tracks.
See here about the difference between saving and exporting: http://manual.audacityteam.org/o/man/au ... jects.html
