separte tracks when recording
raka44
Post by raka44 » Tue Jun 23, 2015 7:22 am
is there a way to have audacity automaticly seperating tracks during capturing?
Re: separte tracks when recording
Post by steve » Tue Jun 23, 2015 10:12 am
No. During capture, Audacity records only*. Any processing or editing is done after the recording is completed.
* During recording you can create labels (http://manual.audacityteam.org/o/man/label_tracks.html) and you can adjust the gain / pan of other tracks that may be playing.
