Howdy!
I apologize if this question has been answered elsewhere but I did not see it when looking around.
But, yeah, my problem is just as the title says: I had to reformat my hard drive recently and lost a bunch of stuff. But, fortunately, I did get to save a bunch of other stuff, too. Within the saved stuff is the Raw Data files of my saved Audacity Projects, which I cannot access due to their missing .aup files.
So question is this: is there anyway I can still access my Project(s) as they were saved in the original .aup file that is now missing?
Thank you for your attention to this problem of mine.
-Curtis79
Lost .aup File but still have Raw Data File
Re: Lost .aup File but still have Raw Data File
Probably not. The AUP file is the instructions of what Audacity should do with all that stuff in the _DATA folder.
http://manual.audacityteam.org/o/man/recovery.html
- Quality Assurance
The link you need is at the bottom of the page Koz cited http://manual.audacityteam.org/o/man/re ... ually.html.
