How do I edit multitrack
newage
Post by newage » Mon Jun 22, 2015 8:50 am
Hello!
How can I edit few tracks in multi-track, just like with Audition:
Re: How do I edit multitrack
Post by steve » Mon Jun 22, 2015 9:13 am
Editing in Audacity is not "just like Audition" because they are different programs. Sure there will be many similarities, but if you really want "just like Audition" then you will have to use Audition. Similarly if you want "just like Sonar" then you have to use Sonar.
newage wrote:How can I edit few tracks in multi-track, just like with Audition:
What happens when you try?
Have you looked at the manual? Perhaps this tutorial will help: http://manual.audacityteam.org/o/man/tu ... music.html
Ensure that you are using the current version of Audacity from here: http://web.audacityteam.org/download/windows
newage
Post by newage » Mon Jun 22, 2015 10:02 am
steve wrote:Editing in Audacity is not "just like Audition" because they are different programs. Sure there will be many similarities, but if you really want "just like Audition" then you will have to use Audition. Similarly if you want "just like Sonar" then you have to use Sonar.
Hi!
I just downloaded the latest version. WHen I open two mp3 songs, they open as separate windows, not in two tracks. There is no search function ih the manual; by going through the poages I found nothing on multitrack editing. I found no button or option in vew to see all tracks together, like in Audition.
When I open two mp3 songs that I want to mix, they open as separate instances.
Post by steve » Mon Jun 22, 2015 11:51 am
As described in the tutorial that I suggested (http://manual.audacityteam.org/o/man/tu ... tml#import) if you use "File menu > Import > Audio" then files will be imported as tracks in the same project. If the files that you want to use are in the same directory then you can select multiple files for importing at the same time.
The difference between "Open" and "Import" is described here: http://manual.audacityteam.org/o/man/fi ... .html#open
More information about importing: http://manual.audacityteam.org/o/man/im ... audio.html
If you wish to move a track to the right so that it does not start at time=0, use the Time Shift tool to slide the audio to the right.
newage
Post by newage » Mon Jun 22, 2015 3:38 pm
steve wrote:As described in the tutorial that I suggested (http://manual.audacityteam.org/o/man/tu ... tml#import) if you use "File menu > Import > Audio" then files will be imported as tracks in the same project. If the files that you want to use are in the same directory then you can select multiple files for importing at the same time.
Thanks! Now I see. I did not know there is difference between Open and Import. In Audition the right mouse button play the role of timeshift - very convenient and handy.
Post by Gale Andrews » Mon Jun 22, 2015 4:27 pm
newage wrote:There is no search function ih the manual
That is something we should fix, but you can bookmark this page and type what you want to search for at the front of the address bar: https://www.google.co.uk/search?q=site% ... team.org/o.
Post by steve » Mon Jun 22, 2015 4:28 pm
newage wrote:In Audition the right mouse button play the role of timeshift - very convenient and handy.
Yes, on Windows, but Mac computers still don't have a proper right-mouse-button.
In Audacity, use F5 key to switch to the time shift tool and F1 to switch back to the selection tool.
