Want to find tone frequency (Hz) for language project
chrisnicolaisen
Audacity Windows 2.1.0
Windows 8.1
I am currently trying to determine the frequency in (Hz) of vowel sounds in American English and Japanese for a linguistics project.
I want to use the (Hz) reading to find corresponding musical notes (C, D, etc.) .
I am attaching a screenshot and the 3.5 second audio file.
I explored the drop down folders, tips, tutorials, and the forums, but I did not find an answer. I think this is probably a simple problem, it is just difficult to find the solution because of how many results pop up from the search criteria.
Thank you very much in advance, and I think Audacity is amazing software!
CN
Windows 8.1
CN
- Attachments
- Screenshot 2015-06-21 15.14.22.png (102.66 KiB) Viewed 540 times
- a i u e o.mp3
- (64.95 KiB) Downloaded 23 times
Re: Want to find tone frequency (Hz) for language project
Nope. Hard problem. Each mouth sound is made of hundreds of different tones, overtones and harmonics. Voices and instruments are all like that. That's why someone who wants to filter out all the French Horns from the orchestra by tones and frequencies is probably not going to be very happy. The horns share a lot of those tones with other instruments.I think this is probably a simple problem
chrisnicolaisen
Thanks, should I just try to use a guitar tuner then?
If it works. The tuner is looking for a powerful fundamental tone and much weaker harmonics on an instrument, so it's easy to see it working. Voices aren't like that unless they're singing.
chrisnicolaisen
I'm definitely open to any suggestions you might have on the best way to get a good reading. Thanks a bunch,
That screenshot is a waveform display. If you select spectrogram display it shows the frequency-content in multi colours ...chrisnicolaisen wrote:I am currently trying to determine the frequency in (Hz) of vowel sounds in American English and Japanese for a linguistics project.
chrisnicolaisen
Excellent! Thank you so much for your help, I really appreciate it!
