Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Rosemarie_Merritt
Post
by Rosemarie_Merritt » Sat Jun 20, 2015 10:59 am
Hi!
I am using the latest version of Audacity on my Windows 8.1 laptop and need some help. I am trying to scrub vocals from a song ("At Last" by Etta James) that is in .cda format that I will be using as an instrumental. I have tried using the Vocal Remover in the effects menu and Invert ( both separately and together) to no avail. The vocals are still at the same volume as the original.
Any help and tips that might help me would be greatly appreciated. Also, if you are going to offer an idea for a specific process, please be specific and go through each step for me because - as I said - I am new to Audacity.
Thank you for your time and assistance!
Gale Andrews on Sat Jun 20, 2015 4:44 pm, edited 2 times in total.
Reason: More descriptive topic title
- Quality Assurance
Post
by Gale Andrews » Sat Jun 20, 2015 1:12 pm
Rosemarie_Merritt wrote:I am using the latest version of Audacity on my Windows 8.1 laptop
Please see the pink panel at the top of this page and give us all three numbers from Help > About Audacity... .
Rosemarie_Merritt wrote:I am trying to scrub vocals from a song ("At Last" by Etta James) that is in .cda format that I will be using as an instrumental. I have tried using the Vocal Remover in the effects menu and Invert ( both separately and together) to no avail. The vocals are still at the same volume as the original.
Have you ripped the song from the CD to WAV? That is better than ripping to MP3.
Rosemarie_Merritt wrote:Any help and tips that might help me would be greatly appreciated.
Here is the page
http://manual.audacityteam.org/o/man/tu ... ation.html.
If the song is not amenable to the tools in Audacity then you can try
Vocal Removal Plug-ins.
This is a good plugin not mentioned there
http://forum.audacityteam.org/download/ ... p?id=12514. Put it in the Audacity Plug-Ins folder and restart Audacity. You must be using Audacity 2.1.0 to use that plugin.
It is often simpler to buy or download a ready-made specially recorded karaoke version of a song than mess around trying to partially remove vocals from the original.
DVDdoug
- Forum Crew
Post
by DVDdoug » Sat Jun 20, 2015 3:40 pm
It's actually a center-channel remover and it rarely makes a "useful" recording. Centered lead instruments are removed along with the voice and there is usually some remaining vocal reverb and/or background vocal.
On my copy of
At Last from
The Best of Chess Records it removed about 90% of the vocal.
Robert J. H.
Post
by Robert J. H. » Sat Jun 20, 2015 7:17 pm
You'll need a stereo version for it to be successful.
Some vocals remain (-40 dB RMS):
Robert
