record vocal+guitar with 2 mics, mixer & laptop on audacity?
karimskarim
Post by karimskarim » Wed Jun 17, 2015 11:46 pm
Hello There,
I started producing podcasts (guitar+vocal) using an iphone app (Audiocopy); now I have been given some interest in recording except that the quality has to improve. In hand I have:
- 2 mics (SM58 SHURE)
- 1 mixer (BEHRINGER XENYX 802)
- lenovo laptop (IdeaPad U260)
- Audacity 2.1.0
Do I have a chance? Am I missing a lot?
Any help is much appreciated as I am on a relatively tight deadline.
Thank you,
Karim.
Re: record vocal+guitar with 2 mics, mixer & laptop on audac
Post by kozikowski » Thu Jun 18, 2015 12:08 am
Just one. The mixer is lovely, and it even has 48v Phantom Power, but it doesn't have a USB connection and the laptop doesn't have an analog input.
I got around that with a Behringer UCA-202 adapter.
http://www.kozco.com/tech/audacity/pix/ ... vo-650.jpg
That also happens to be one of the devices I certified for overdubbing, should you want to play with yourself, so to speak.
Post by steve » Thu Jun 18, 2015 12:12 am
Unless you have a USB interface that you have not told us about, the weak point is the sound card in the laptop.That can be easily and cheaply remedied by adding a Behringer UCA 202 (or similar) USB sound card (about $30).
The other glaring omission is what you listen to your recording with. It's impossible to make a good mix using crappy computer speaker. Studio monitors are terrific but expensive. Headphones range from terrific to awful, but give the best performance on a budget. Avoid headphones that advertise "pumping bass" or similar - ideally you want headphones that give an accurate "neutral" sound.
SM58s are good "stage" microphones and last forever - extremely tough, but can be a little dull for recording. Nevertheless, they are capable of giving pretty reasonable recording. Ensure that you use proper XLR mic leads with them - no 1/4" jacks.
The really important thing that everyone misses out of their description is the "room". Where you record is really important. It must be a quiet as possible and free of excessive echoes. Soft furnishings can help to damp down echo/reverberation. Noise and echoes will kill your recording before you start - I can't over-emphasize the importance of the room.
Post by kozikowski » Thu Jun 18, 2015 12:16 am
What most people think of when they say "make it sound better" is eliminate the honky room echoes and traffic noises outside.
You can do really well with an ordinary microphone in a quiet room with no echoes (a studio), but it doesn't work the other way around. It doesn't matter how much money you blow on a microphone, mixer, etc, etc, if the room doesn't cooperate, that's the end of the story. No, there's no "remove echo" button.
That's not to say it's impossible. Newsies have been doing interviews in noisy rooms for a long time.
That's not a cheap microphone and it's not particularly musical, but it does do one thing really well, only receives sound from the front.
Post by kozikowski » Thu Jun 18, 2015 12:27 am
I did a very nice recording with all the equipment you see. The laptop is shut, but work with me here.
http://www.kozco.com/tech/MicTests/timc.wav
What you don't see is the rest of the A Building, Main Conference Room which is soundproofed. No noise and very little echo.
Post by kozikowski » Thu Jun 18, 2015 12:33 am
Is that fast enough?
blackdog3
Post by blackdog3 » Fri Jun 26, 2015 8:16 am
Hello, I have only today ordered a uac 202 interface, based on what i read on the forum. I want to hook up the laptop to the mixer via the behringer interface, but am new at this. I see from the pic you posted Kos, it is 2 RCA from the interface into the mixer, but what is on the other end plugging into the mixer? is it 2 RCA or 1/4 inch? can u show a pic?
I am a beginner at this.
Post by kozikowski » Sat Jun 27, 2015 2:58 am
On my mixer, I'm using Tape Out and it's another RCA Stereo.
http://www.kozco.com/tech/audacity/pix/ ... apeOut.jpg
So the interconnecting cable is RCA stereo to RCA stereo—for me.
Your mixer has 1/4" connections for Left and Right. I would use 1/4" adapters to RCA like the attached picture (get two)(it might be called a 6.35mm connection or plug). From there, it's just a plain RCA stereo cable.
These cables are getting harder and harder to find. Not the cable type, but everybody wants to up-sell you into Custom Gold Plated, Super Insulated, 12M long, Double Braid Shielded, etc. etc. etc. None is necessary on short cable runs.
http://www.amazon.com/C2G-Cables-Value- ... +rca+cable
Radio Shack in the US used to offer plain, four foot RCA stereo cables.
Screen Shot 2015-06-26 at 7.41.26 PM.png (59.25 KiB) Viewed 574 times
blackdog3
Post by blackdog3 » Sat Jun 27, 2015 6:24 am
Hey thankyou so much for helping. I have a little mixer I hope this pic comes out.
so mine doesn't have the outs on the back, just rca tape out. if I adapted those rca to make them stereo, I am not sure where to put the outs. one of the main outs on the unit is used to hook up an active speaker. I only have one of these. Line one is a microphone shure sm58. For the first time last week tried to record via laptop and audacity 2.05 the voices of the singing group we are in, and the music, but from the little I heard of it, (someone else's laptop) the music was distorted, and no voices. This is our first try. I figured that without that interface, i went wrong, and I think it might be levels on units also.
Tell me if I am close. grin.
Post by kozikowski » Sat Jun 27, 2015 11:52 pm
Almost all modern computers need a little help hooking up a mixer. Last time I bought a new computer, I bought an old design just so I could get the Stereo connections. The new design doesn't have them.
You can't use most computer Mic-In connections to connect a mixer. The connection overloads very easily and made your sound loud and crunchy, but more important, they're mono, not stereo, so that's probably where your voices went.
http://www.kozco.com/tech/audacity/pix/LaptopMicIn.pdf
I'm fuzzy where you have your speaker system plugged in. It should be connected to the Control Room Out, Left and Right. That's the same signal that appears on the headphone connection and they're both adjusted by the PHONES/ CTRL ROOM knob. It's important that you work it that way,because if you don't, adjusting your headphones will mess up your show.
The mixer has two copies of The Show. The two RCA connections TAPE OUT, Left and Right, and CTRL ROOM OUT, Left and Right. You can connect the Tape Outs to the UCA202 when it gets here and you should be good to go. You can also use two of those 1/4" adapters to turn CTRL ROOM OUT into two more RCAs and those would work, too.
It's a terrible idea to run microphones and speakers in the same room. Live recordings are done on headphones.
http://kozco.com/tech/audacity/wynonna2.jpg
