Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
ChristineG
Post
by ChristineG » Tue Jun 16, 2015 10:13 pm
Hi
I posted for the first time recently about click removal, and managed to remove all the problems, except for four pops. I have been trying to use the EZ=Patch plugin by Steve Daulton on those four. I have been following the enclosed link
http://forum.audacityteam.org/viewtopic ... 42&t=62384 but each time I select an area I am getting a double or repeat note or chord replacing the pop, regardless of whether I chose the before or after setting. Each pop is about 0.3 of a second when zoomed in. They are too long for Pencil Tool or Repair Tool, and i am not skilled enough to do it by Spec' editing despite the wonderful Youtube video by PaulL. I would be grateful for any help. Thanks.
PS I have tried Notch Filter in bothe Audacity and REAEQ, but cant get it exact.
ChristineG
Post
by ChristineG » Wed Jun 17, 2015 12:15 am
Thanks for the quick reply Steve. In the enclosed sample I have a couple of bits of mud at about two and four seconds. There are a couple of other examples on the whole track, but I have solved everything else. I think I am on the right lines with EZ-Patch, any improvements on this idea would be gratefully received. Thanks.
- Test Wav.wav
- (863.56 KiB) Downloaded 13 times
- Site Admin
Post
by steve » Wed Jun 17, 2015 4:16 pm
ChristineG wrote:In the enclosed sample I have a couple of bits of mud at about two and four seconds.
It sounds as if you have already attempted a repair in those places. Do you still have the original unedited version of that part?
ChristineG
Post
by ChristineG » Wed Jun 17, 2015 4:59 pm
Thanks for the quick reply Steve. I am guilty as charged, I did run a repair on it before presenting it. I ran PaulL's De-Clicker on it. I was only left with four bits of mud sounding data. The rest was passable and just needed some filter work, and equalising. I could have done the first click in the demo wav manually which was easy enough. The second one however was in the original which I have supplied. It is too long for Pencil Tool or Repair Tool, which is why I was looking at EZ-Patch. The guitar work is too intricate, it sticks out like a sore thumb if I do a delete. I am not skilled enough yet for Fade in and Fade Out manually after a delete.Any help or suggestions would be wonderful. Thanks again.
- Test Wav2.wav
- (889.78 KiB) Downloaded 14 times
ChristineG
Post
by ChristineG » Fri Jun 19, 2015 12:21 am
Thanks so much Steve for your help and excellent fix, this is now solved. The Repair Channel add on is a wonderful addition, and has saved me so much time. Thanks again.
- Site Admin
Post
by steve » Fri Jun 19, 2015 12:31 am
I've done a fair bit of "audio restoration" and it's always a challenge. i tend to be quite wary of restoration effects that are applies to the entire track - always keep a backup!
One useful technique is to duplicate the original track (select the track the Ctrl+D), mute the original track, and work on the duplicate. If you produce a "bad bit" in the duplicate track, you will probably be able to cut and paste from the original onto your "repaired" track to "revert" the bad bits back to the original.
