No Audio
Gerard 56
No Audio
Post by Gerard 56 » Thu Jun 11, 2015 11:21 pm
I cant get any audio when I play my Lps And no Audio at all since I downloaded audacity
Re: No Audio
Post by steve » Thu Jun 11, 2015 11:57 pm
Are you using a USB turntable?
Are you using the current 2.1.0 version of Audacity? (look in "Audacity from Help > About Audacity" for the exact version number)
Which version of Windows are you using?
Re: No Audio
Post by Gale Andrews » Fri Jun 12, 2015 5:35 pm
If it's a USB turntable, set Windows back to use your speakers or headphones, or simply disconnect the turntable. See Why have I lost sound after connecting a USB device on Windows?.
If you want to hear the LP while recording, enable Transport > Software Playthrough in the Audacity menu at the top of the screen.
If you want to hear the LP without recording, click on the Audacity recording meter as well as enabling software playthrough.
