tHANKS for the info,
Ive changed the setting s and did see the word ... loop back ... in box 3 , not box 2
Just went on internet radio and did a recording............. Bingo it worked ...
quality of sound on that little clip exellent too !
recording internet radio [SOLVED]
stardust2003
