Playback
Will2sr5
Playback
Post by Will2sr5 » Thu Jun 04, 2015 8:27 pm
Hi!
My name is Will and I am having difficulty with playback sound after a recording. What is my problem, and how can I fix it? Is ther a video I can view? :?:
I do have sound when recording, just not any when play back. Will appreciate your advice.
Thank you very much.
Will
Re: Playback
Post by kozikowski » Thu Jun 04, 2015 8:35 pm
Describe your computer and how you're listening. Do you have headphones plugged into the green soundcard socket? What are you recording? USB microphone?
Which Windows and which Audacity?
Will2sr5
Re: Playback
Post by Will2sr5 » Thu Jun 04, 2015 10:07 pm
I am using windows 7
I am using Audacity 2.0.3
I am using external mike ( cassette player).
Will2sr5
Re: Playback
Post by Will2sr5 » Fri Jun 05, 2015 8:13 am
Ok, now that I have playback, I get an echo. Is there a change of setting to get rid of the echo?
Would it be 1950s music could be mono instead of stereo?
Re: Playback
Post by Gale Andrews » Fri Jun 05, 2015 11:43 am
Will2sr5 wrote:I am using windows 7
2.0.3 is very old. I recommend the latest 2.1.0 from http://web.audacityteam.org/download/windows.
Recording music from a cassette player with an external microphone is desperation measures. If you have a separate line-in (blue) and mic in (pink), connect to the line-in and choose the line-in as recording device in Audacity's Device Toolbar.
After obtaining 2.1.0, see Copying tapes, LPs and other media to CD or computer - Audacity Manual.
Will2sr5 wrote:Now that I have playback, I get an echo. Is there a change of setting to get rid of the echo?
Choose the correct recording device in Device Toolbar. If you record from the external mic, choose that as the recording device. If you record from stereo mix or the internal mic in error you may record echoes.
