Sometimes I get a freeze up when I hit the record or play button. Any ideas what's happening and how to set it straight?
Jay
Using Windows 7, freeze up
Jay Markwart
Re: Using Windows 7, freeze up
http://www.kozco.com/tech/audacity/Docu ... tions3.pdf
Which Audacity are you using? We need the accurate number, not an abbreviation.
