How to edit out 'distortion' in an MP3
jccarrell
Post by jccarrell » Sun May 31, 2015 7:33 pm
I recorded the Trisagion off the internet, but from 3.4 on until the end, there is some distortion that is not present from the beginning to that point.
Can I edit this out, and how do I do that?
Re: How to edit out 'distortion' in an MP3
Post by kozikowski » Sun May 31, 2015 8:21 pm
Three seconds? Three minutes?
Can you drag-select a ten second segment with the distortion starting in the middle? File > Export Selection and post it? Use WAV (Microsoft) for the export quality.
From a forum message window, scroll down, Upload Attachment > Add the file.
Also forward your computer info and Which audacity version.
jccarrell
Compressed audacity file attached
Post by jccarrell » Mon Jun 01, 2015 9:49 pm
I am so new to the software that I don't know how to edit a ten-second clip.
I am trying to upload an Ogg-Vorbis compressed version of the project.
If this won't work for you, if there's an email address, I can notify you
of where you can pick up the audacity project through my dropbox account.
Thanks,
John
trisagion-c.aup
I compressed the original aup project to a compressed.
(591 Bytes) Downloaded 45 times
Re: Compressed audacity file attached
Post by Gale Andrews » Tue Jun 02, 2015 5:25 pm
You still have not told us which Audacity version and which version of Windows. Please tell us (have a look at the pink panel at the top of the page).
jccarrell wrote:I am so new to the software that I don't know how to edit a ten-second clip.
Pretend the blue waves are text. Drag the audio you want to select with your computer mouse, as you would drag select some text. Then export as WAV. Have a read of How to post an audio sample.
jccarrell wrote:I am trying to upload an Ogg-Vorbis compressed version of the project.
AUP files are only text files, no audio.
The _data folder of your project has one OGG file for each track in your project, if you used File > Save Compressed Copy of Project.
You cannot attach files larger than 2 MB. There is no e-mail address. Please right click over the audio file in Dropbox, choose Share, then post the address of that file here.
jccarrell
Post by jccarrell » Wed Jun 03, 2015 8:43 pm
My Audacity version 2.1.0
My OS version: Windows XP SP3
Dropbox location of 10-sec WAV snippet: https://www.dropbox.com/s/6kw9x25zwnhhd ... V.wav?dl=0
Original Internet Location: http://crashinglybeautiful.tumblr.com/p ... y-god-holy
If more is needed from me, let me know.
Thank you for your followup and determination to help me.
Sorry I am such a Noob.
John
Post by Gale Andrews » Thu Jun 04, 2015 1:17 pm
jccarrell wrote:My Audacity version 2.1.0
Make sure you read Important information for Windows XP users.
jccarrell
Post by jccarrell » Thu Jun 04, 2015 5:53 pm
Thank you, Gale. My WindowsXP SP3 is up to date.
Post by kozikowski » Thu Jun 04, 2015 8:27 pm
Just to be clear, it can't be up to date. Microsoft stopped providing updates and they warned that they were going to do that. It is dangerous to put a Windows XP machine on the internet. You will be vulnerable to all the attacks that were designed after Microsoft stopped.
Post by Gale Andrews » Fri Jun 05, 2015 10:30 am
jccarrell wrote:I recorded the Trisagion off the internet, but from 3.4 on until the end, there is some distortion that is not present from the beginning to that point.
It's too loud (over 0 dB) which means the tops of the waveform that are over that level can't be represented. The result is a "flat topped" waveform and the distortion you hear.
You won't remove the distortion - you can make it a little better by using Amplify at -20 dB then Clip Fix. Clip Fix just looks at the waveform and tries to guess what the tops of the waveforms should have been and interpolates those values. I used a setting of 85 in Clip Fix but you can choose what's best.
But really, look for another recording of that piece.
