How to make one file come after another
ExhibitRapper
I NEED HELP, I'm trying to make One Audio File come after another, When I import the 2nd one, I can't find anyway to move it to the spot after the first one ends. I'm trying to have it where after the first song ends, A second one comes immediately after, all in the same track. HELP
Reason: Give topic a relevant title
Re: How to make one file come after another
Use the Time Shift tool to slide the second track to the right.
ExhibitRapper wrote:I NEED HELP, I'm trying to make One Audio File come after another, When I import the 2nd one, I can't find anyway to move it to the spot after the first one ends. I'm trying to have it where after the first song ends, A second one comes immediately after, all in the same track. HELP
After loading one file per track, select the tracks you want to align and do an align end to end
