editing functions not working [SOLVED]
innovant2015
Post by innovant2015 » Fri May 29, 2015 4:59 pm
2.06 exe
None of the cut, copy paste functions are working on a wav or mp3. They were working earlier.
Re: editing functions not working
Post by kozikowski » Fri May 29, 2015 5:15 pm
Many of the tools and services top working when you're in Pause instead of Stop.
We don't make a 2.06, and 2.0.6 is far out of date.
Download and install 2.1.0 from here.
http://web.audacityteam.org/download/
If you stick with 2.06, some of the tools and help aren't going to work. When the installer asks you if you want to reset the preferences, say yes.
innovant2015
Re: editing functions not working [SOLVED]
Post by innovant2015 » Fri May 29, 2015 9:05 pm
Thanks! Downloaded latest version and everything works.
