Set different out to each track
mrmotown
Post by mrmotown » Mon May 18, 2015 7:18 pm
Hi,
i would like to use audacity for live Concert.
I need at least 2 tracks,
one for the click and another one stereo
for the music.
I use an external audio interface (Native-instruments Audio Kontrol 1) in order to have 4 different output.
My question is :
With Audacity it is possible to set a different output
to each track (tipically click in out 1 and music in out 2/3) ?
Thanks !
Re: Set different out to each track
Post by steve » Mon May 18, 2015 9:50 pm
mrmotown wrote:With Audacity it is possible to set a different output
to each track
No. Audacity can only play a maximum of two channels through one device.
You may be able to do what you want with a DAW application such as Reaper, Sonar, Cubase or similar.
