Program not launching [SOLVED]
joaorcmelo
Post by joaorcmelo » Sun May 17, 2015 3:48 pm
For some reason Audacity is not opening anymore.
I already tried re-installing it, but it didn't work.
It's really weird since I was using it last night and nothing went wrong with it.
Re: Program not launching
Post by kozikowski » Sun May 17, 2015 3:58 pm
We need the information from the pink band above this thread. Which Audacity? Which Windows?
joaorcmelo
Post by joaorcmelo » Sun May 17, 2015 4:15 pm
Download Audacity 2.1.0
Windows 8
Post by steve » Sun May 17, 2015 6:02 pm
Try reinstalling Audacity from the recommended installer (http://web.audacityteam.org/download/windows)
During the installation, look out for the option to "Reset Preferences" and select that option.
joaorcmelo
Re: Program not launching [SOLVED]
Post by joaorcmelo » Sun May 17, 2015 9:38 pm
It worked!
Thanks :D
Post by steve » Sun May 17, 2015 11:04 pm
Thanks for letting us know.
Marked as solved..
