installation of v.2.1.0 changes icon props for excell 2010
Re: installation of v.2.1.0 changes icon props for excell 20
Post by steve » Wed May 13, 2015 6:12 pm
surfing69 wrote:If I may make an observation - if one doesn't know the cause of the problem, then one may not be looking in the right place or using the 'correct terms' in a Google search (?) Furthermore, a good set of search results will depend on the structure of the search term.
Absolutely, I quite agree, but I'm far from the greatest user of Google and found loads of references to the issue straight away
I just used the terms: excel unknown icon
Finding specific useful results took a bit more hunting.
surfing69
Post by surfing69 » Sat May 16, 2015 11:06 am
well - all the above may be irrelevant know.
When I installed Audacity 2.1.0 on my friends laptop running Win7 and Office 2010, there were NO observable issues with icon appearance or anything else.
I therefore tried to install v 2.1.0 again on my desktop and on this occasion everything went to plan and the Excel icon remained stable.
Looks like the issue resolved itself - somehow.
