Trying To Edit Clips Taken from a Larger File??!!!
Canadia99
Post by Canadia99 » Mon May 11, 2015 2:56 am
Hi there- I've run into a rather unique (read: frustrating) problem with editing a 2-minute music clip. It was taken from a MUCH larger recording my band made one night, of over 4 GB (about 2 hours in length). WAV format.
I can isolate (clip out) songs from the session into their own respective files, but because they're so compressed (not sure that's the term that applies to the problem, exactly) I can't apply fade in/out, nor access smaller parts of the song to edit out. The graphic shows the clip as being about an inch wide, and I simply can't align the cursors with any accuracy to accomplish what I want to do.
Is there a way to expand the file, so I can have a wider visual template to allow more accurate editing?
Any suggestions would be appreciated.
Thanks
Chris
Version 2.10
Re: Trying To Edit Clips Taken from a Larger File??!!!
Post by kozikowski » Mon May 11, 2015 4:23 am
The Zoom tools might be handy. I use three.
Control-F Zoom Full. fill the screen with your current show.
Control-E Drag-select some portion of the show and zoom into it.
Control-3 Zoom out a little bit.
There are many more.
http://manual.audacityteam.org/o/man/zooming.html
It's also handy for me to stop the screen from Auto Scrolling.
Audacity > Edit > Preferences > Tracks > [_]Update... (de-select)
You probably want to turn that back on for recording.
Post by Gale Andrews » Mon May 11, 2015 1:48 pm
Canadia99 wrote:The graphic shows the clip as being about an inch wide, and I simply can't align the cursors with any accuracy to accomplish what I want to do.
As an alternative to zooming you can enter the times of selections or the editing cursor in Selection Toolbar.
Canadia99 wrote:Version 2.10
Hopefully you meant 2.1.0 with the extra dot. ;)
Post by kozikowski » Mon May 11, 2015 1:57 pm
2.10 is a bogus version of Audacity. You can get The Real Thing from here.
http://web.audacityteam.org/download/
