VST classic Limiter
davidrbroder
VST classic Limiter
Post by davidrbroder » Sun May 10, 2015 10:44 pm
according to google to ad a plug in to the effects you need to open the register effects dialogue box. But I can find no such thing on Audacity. How do you ad a plug in to the effects.
Re: VST classic Limiter
Post by steve » Sun May 10, 2015 11:37 pm
davidrbroder wrote:according to google to ad a plug in to the effects you need to open the register effects dialogue box. But I can find no such thing on Audacity. How do you ad a plug in to the effects.
In the manual is a "Frequently Asked Questions" section: http://manual.audacityteam.org/o/man/faq.html
Many of the most common questions are answered there, including: http://manual.audacityteam.org/o/man/fa ... st_install
