behringer guitar link
r.washenberger
I can't get the headphone output to work on my usg102 guitar link. I'm using windows 7 and audacity. Any ideas?
Re: behringer guitar link
There's a Behringer UCG-102.
Do you have the headphone volume control turned up on the side?
If you have headphones with a mini plug, did you get the right adapter?
http://www.sweetwater.com/store/detail/ ... fgodSKgAig
r.washenberger
yes, I have the volume up and have the right adapter I wonder if the unit could be defective
r.washenberger
Yes it is a UCG102. I have it turned up and have the right jack but no sound.
Can you record the guitar? If the unit has lights, are they on?
If you set the unit for playback in Windows and Audacity, can you hear Audacity playback?
Can you try any of this on another computer — like maybe your old one.
r.washenberger
yes, everything seems to work but the headphones. But I'm having trouble with downloading the driver where it says configure the driver for audio applications. It says start the ASIO-USB Control Panel from within the audio software (may be called ASIO Config or similar) I can't find the control panel?
Audacity doesn't directly support ASIO, so don't bet the farm on that one. Yes, if everything works but the headphone, the unit may be fried. As First Level Maintenance, I would pull the headphone plug out and scrub it with Windex, alcohol, or vodka. Dry thoroughly. Plug it in and turn it a couple of times. If you're using an adapter, scrub both plugs. Don't use lotion-impregnated tissues.
Of course make sure your headphones play somewhere else, with the adapters.
Do you remember where your receipts are?
r.washenberger
Yeah, I just got it yesterday but can you tell me if the light on the unit is on should the headphones work or is it something else in the download part of it that powers the headphones?
r.washenberger
Also, why does behringer supply an asio driver for use with audacity?
If the USB light is on, the unit should be working. Did you try playing to the unit? Set the unit as a playback device.
Audacity is included with everything because it's free and it runs on any computer. It's usually out of date and we advise getting the latest one (2.1.0) from here.
http://web.audacityteam.org/download/
