I'm using 2.1.0 on Win 7 x64. I'm ripping old vinyl and have been labeling the tracks. When using File > Export Multiple... each track was being saved as individual files (flac or wav). Has been working well for a few weeks.
Something has changed. Now, Export Multiple is exporting all the labelled tracks as a single file. I probably inadvertently did something to cause this but I don't recall making any changes. I don't want to start mucking around in Preferences before I understand what is the cause. I've looked but I don't see anything odd.
Anyone have an idea of how to fix this?
Labeled tracks not being exported [SOLVED]
- Quality Assurance
Re: Labeled tracks not being exported
If you have more than one label track, only the uppermost label track is respected for Export Multiple.
I'm missing something. Yesterday, when I labeled six tracks (Ctl-B or -M), Export Multiple would create six files. Today, when I label six tracks, Export Multiple creates only one file. How do I get back to making a file for each label?
If all of the labels are in the same label track, then all labeled regions should be exported.jvinton wrote: >> more than one label track, only the uppermost
If you have two or more "label tracks", then only the labels in the first label track are used.
Re: Labeled tracks not being exported [SOLVED]
Yes, there was a second label track. I was above the audio track and mostly collapsed. I have no idea why or even how I added it. Removing it solved the export problem. Thank you for your help.
