I am currently running Audacity "2.0.1".
I had a song recorded, I saved and closed my laptop. Screen froze when I opened it an hour later. Now when I try and open the .aup file it gives me a unknown file type error. I have the .aup file, and data files all there untouched. What could be going wrong?
I need help with my latest Audacity project
Collodrollo
Re: I need help with my latest Audacity project
Restart the machine. You may be trying to use a partially damaged Audacity. It will be interesting to see if Audacity restarts after the machine comes back up.
Oh, we need the Windows version.
- Quality Assurance
Attach the AUP file if you still cannot open it. Please see here for how to attach files: http://forum.audacityteam.org/viewtopic ... 49&t=64936.
Audacity 2.0.1 is old now. I suggest you obtain the latest 2.1.0 from http://web.audacityteam.org/download.
