RECORDING STEREO FROM TURNTABLE
unied4
Post by unied4 » Wed Apr 22, 2015 1:14 am
I have a PC with Windows 7. When I record in Audacity from my Encore Technology turntable I indicate 2(stereo)inp in the Audacity recording screen. My headset is plugged into my turntable and the sound I hear is in stereo. However, the music appears to record in mono not stereo. How do I record in stereo ?
Re: RECORDING STEREO FROM TURNTABLE
Post by kozikowski » Wed Apr 22, 2015 3:21 am
USB Turntable?
Close Audacity and find the turntable in the Windows Control Panels. Does the sound meter jump with the music and is there a setting for Mono/Stereo?
If you have your turntable plugged into the analog Mic-In, that connection is usually mono.
Post by Gale Andrews » Wed Apr 22, 2015 6:10 am
