Older versions of the alpha builds are stored so you could continue using the new features that do work by going back to the alpha build before the problem started.юра00 wrote:Thank you, but I consider, that nightly builds loose a lot of sense, when the Nyquist plugins are unapplicable.
If you click the link on the download page that says "View Audacity latest commit changes" you can see the changes that were made at the point each alpha was built, and you can see if any of the latest commits say that they have fixed problems with the effects.
If you don't understand what any of that means then you probably should not be using alpha builds.
