Everything is gone and I'm crying
kristen2335
I was recording something for a school project and my computer crashed and shutdown in the middle of it. I think it autosaved my stuff, but everytime i try to recover it, it says "Error: not well formed (invalid token) at line 1045.
help me please i beg you
- Attachments
- ihiuh - 2015-04-19 21-07-46 N-44.autosave
- (59.49 KiB) Downloaded 53 times
Re: Everything is gone and I'm crying
Keep a copy of your original autosave file somewhere safe, then try replacing the original autosave file with this version:
- Quality Assurance
You will need to fix that because it is probably a problem with the audio or video drivers on your computer and it will very likely happen again. Please see here for what you can do about it: http://manual.audacityteam.org/o/man/fa ... tml#reboot.kristen2335 wrote:I was recording something for a school project and my computer crashed and shutdown in the middle of it.
kristen2335
I replaced it and opened it, but there is no sound. Like it still has 17 minutes worth of stuff, but no sound.steve wrote:Keep a copy of your original autosave file somewhere safe, then try replacing the original autosave file with this version:
- Quality Assurance
Is the audio just a flat line 17 minutes long?kristen2335 wrote:I replaced it and opened it, but there is no sound. Like it still has 17 minutes worth of stuff, but no sound.steve wrote:Keep a copy of your original autosave file somewhere safe, then try replacing the original autosave file with this version:
Can you choose Help > Show Log... top right of Audacity, save the log file and attach it. The log should tell us why there is a problem. Please see here for how to attach files: http://forum.audacityteam.org/viewtopic ... 49&t=64936.
Now, be sure to leave Audacity running until we find out what the problem is. If you need to shut down the computer, you must use Windows Task Manger to quit Audacity, and not use any commands in Audacity to quit or close the project. If you need to, use CTRL + SHIFT + ESC to open Task Manger, find the "Processes" tab, right-click over "audacity.exe" then choose "End Process Tree". That will keep the data and the AUTOSAVE file safe.
kristen2335
Gale Andrews wrote:Is the audio just a flat line 17 minutes long?kristen2335 wrote:I replaced it and opened it, but there is no sound. Like it still has 17 minutes worth of stuff, but no sound.steve wrote:Keep a copy of your original autosave file somewhere safe, then try replacing the original autosave file with this version:
- Attachments
- log.txt
- (56.46 KiB) Downloaded 21 times
- Quality Assurance
What version of Windows are you using?
Audacity can't find the AU files in "C:UsersKristenDocumentsihiuh_data". Are you user "Kristen"?
If you are Kristen, open that "C:UsersKristenDocumentsihiuh_data" folder in Explorer. You should see only one folder, "e00", and no "AU" files. Is that what you see?
Double-click the "e00" folder to open it. You should see only two folders "d00" and "d01", and no AU files. Do you see that?
Now double-click the "d00" folder to open it. You should see (I think) 292 AU file (only 256 of those AU files are actually your recording).
Go back to the "e00" folder and double click on the "d01" folder. You should see 92 AU files (2 of those are not part of your recording). Do you see that?
If you see AU files anywhere else in "C:UsersKristenDocumentsihiuh_data" that is why Audacity cannot find the files. If so, what you can do is look at the fourth number in the file names of the AU files (after the "e" in the name). If that fourth number is "0", put that file in the "d00" folder. If that fourth number is "1", put that file in the "d01" folder.
For example, file "e00002f2.au" should go in the "d00" folder.
If you do that and the AU files have the correct audio, then you will get your recording back.
There is another solution, but this is the simplest one to try first.
kristen2335
I'm running windows 8.1
I went to "C:UsersKristenDocumentsihiuh_data". and saw "e00" and no "AU" files.
Inside of the "e00" folder I saw "d00" and "d01", and no AU files.
In the "d00" folder I saw the 292 AU files and in the "e00" folder I saw the 92 AU files.
There were no other AU files anywhere in the"C:UsersKristenDocumentsihiuh_data" folder.
Still no sound. Should I try to open up these AU files individually?
- Quality Assurance
That looks OK, if you meant that the 92 AU files were in "d01".kristen2335 wrote:I'm running windows 8.1
But there is some reason Audacity cannot access those files.
I would use Windows Task Manager to force quit Audacity (after you open it, click "More details" if you see that, then the "Processes" tab, then "right-click over Audacity and "End process tree"). This retains the AU files in the _data folder as they were.
Then rename "ihiuh - 2015-04-19 21-07-46 N-44.autosave" to some other extension like ".auto"
(so rename to "ihiuh "2015-04-19 21-07-46 N-44.auto") or move that file to your Desktop. This lets Audacity launch without the Automatic Crash Recovery Dialogue (but you can still rename the file to ".autosave" if you need to use the Automatic Crash Recovery dialogue again).
Now select "C:UsersKristenDocumentsihiuh.aup" and "C:UsersKristenDocumentsihiuh_data" and copy them to your Desktop so you have a backup.
Yes after force quitting Audacity, launch it again then drag in some of the files that are are marked as "missing" in the log such askristen2335 wrote:Still no sound. Should I try to open up these AU files individually?
C:UsersKristenDocumentsihiuh_datae00d00e00009c8.au
C:UsersKristenDocumentsihiuh_datae00d00e00004c3.au
C:UsersKristenDocumentsihiuh_datae00d01e0001a93.au
If those files have proper blue waves, just quit Audacity normally without saving changes.
Next open "C:UsersKristenDocumentsihiuh_datae00" and select the files in the "d00" folder that are marked as "orphan block files" in the log. Here is the list of the orphans in "d00":
Code: Select all
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000005.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e000003d.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000108.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000176.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000276.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e00002c3.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e00002c9.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e000030e.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000317.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000373.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000410.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e00004dd.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e000059a.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e00005d4.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e000065f.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000675.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000677.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e00007ad.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e00007ca.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000837.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000904.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e000095c.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e000099e.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e00009e3.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000a17.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000b5e.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000bf2.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000c95.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000cf0.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000d2a.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000dbe.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000e55.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000f0a.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000f3e.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000f78.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d00e0000f9f.au'
Then cut and paste these two orphan files from "d01" to your Desktop:
Code: Select all
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d01e000122f.au'
7:41:10 PM: Warning: Orphan block file: 'C:UsersKristenDocumentsihiuh_datae00d01e000140f.au'
The next steps are explained in detail here: http://manual.audacityteam.org/o/man/re ... very_tools.
In summary, you sort the AU files in the "d00" folder by time modified, rename them while time-sorted so the file names run in an alphanumerical sequence, then use the "Audacity 1.2 Recovery Tool" to make a single WAV file out of those files. Tell Recovery Tool to make a stereo (2 channels) file.
Then repeat the same process for the files in the "d01" folder.
Then all you should need to do is import the two WAV files, the one made from the d00 folder first, then the one made from the d01 folder. Drag the WAV made from d01 after the end of the WAV made from d00. Note that you may find some brief sections where the left channel's audio is in the right channel and vice-versa. If you include the orphan files, these might mainly appear at the start of the first WAV, but there is no guarantee about that.
Another observation is that it is possible a misbehaving anti-virus application is interfering with Audacity's _data folder. Or a virus on your computer could be the cause of the problem. If you suspect the former, you could disconnect the internet then configure or close down the anti-virus application. If other applications than Audacity are behaving strangely, then you should force quit Audacity and run an anti-virus check before doing anything else.
kristen2335
I renamed the file to "ihiuh- 2015-04-19 21-07-46 N-44.auto" and copy and pasted "C:UsersKristenDocumentsihiuh.aup" and "C:UsersKristenDocumentsihiuh_data" to my desktop.
Then I tried to drag the files marked as missing into the log, but there were no blue waves at all.
I also looked for the orphan block files in the "d00" and "d01" folders of C:UsersKristenDocumentsihiuh_datae00, but none of them were not in there at all.
