Export problem in File 6 channels
FutMan
Post by FutMan » Sun Apr 19, 2015 6:39 pm
Hello :D ,
I use Audacity hugely 2.02 (.exe installer) with windows seven SP1. Today I wanted to export a 6 channel AC3 file and Audacity said "In the Exported file, your tracks will be mixed into a single channel." I uninstalled and installed again but it did not fix the problem.
What's going on there?
Best Regards
Translated with Google
DVDdoug
Forum Crew
Re: Export problem in File 6 channels
Post by DVDdoug » Sun Apr 19, 2015 7:21 pm
Go to Edit -> Preferences -> Import/Export and choose Use Custom Mix.
FutMan
Post by FutMan » Sun Apr 19, 2015 8:16 pm
Thank you very much it works. It is not by default? (I also had to change in 448 kbps and 48000 Hz) I do not remember. Long ago I installed Audacity. I had a blue screen, it is probably this that has deregulated Audacity ;) ...
Best Regards.
Translated by Google
