ACC Export gone?
Jynks
ACC Export gone?
Post by Jynks » Thu Apr 16, 2015 7:11 am
Hi there... I'm using 2.0.2, and when I go to "file/export" there is no options to export ACC? Is there a 3rd pary plugin or something?
Re: ACC Export gone?
Post by steve » Thu Apr 16, 2015 10:32 am
I think you may mean "AAC" (http://en.wikipedia.org/wiki/Advanced_Audio_Coding)
It is listed as:
M4A (AAC) Files (FFmpeg)
As in previous versions of Audacity, FFmpeg needs to be installed for AAC export: http://manual.audacityteam.org/o/man/fa ... tml#ffdown
Post by Gale Andrews » Thu Apr 16, 2015 9:28 pm
steve wrote:I think you may mean "AAC" (http://en.wikipedia.org/wiki/Advanced_Audio_Coding)
It is listed as:
Note that to use the 2.2.2 version of FFmpeg linked to there, you must update to the current version of Audacity from http://audacityteam.org/download/windows.
